Шестое поколение iPhone компании Apple, представленное 12 сентября 2012 года. Ремонт данного устройства схож с предыдущими моделями, требующий отвертки и инструменты для вскрытия. Доступен в версиях GSM или CDMA; с 16, 32 или 64 ГБ памяти; в Черном или Белом цвете.
2522вопросов Показать все
Вопрос закрыт
LCD display horizontal lines
So I replaced the screen of my iphone a couple of days ago, thinking it'd fix everything and such. Didn't do it correctly and I wonder if I broke the cable in the process or if it's a motherboard/connector issue because the screen has been flickering, horizontal lines and the icons on the screen are 'doubling'. So...would a new screen assembly do the job or do I need a new logic/motherboard?
Something like this https://instagram.com/p/BDV-DaOPgFSG1NQQ...
https://instagram.com/p/BDV-K7CvgFeNxhYd...
Additional: setting it to high brightness made it go dark
Это хороший вопрос?
Оценка 0
2 Комментариев:
this is normally:
damaged connection
damaged connector
damaged screen
or a lose connection
из
How do I tell the difference? What should I examine? I mean, maybe I just bent the cable, but...
из
Добавить комментарий
2 Ответов
does it do the same thing with the old lcd?
Был ли этот ответ полезен?
Оценка 0
2 Комментариев:
Well, the original one had water damage and it's been somewhat similar as in unresponsive but since I 've removed the screens many times maybe I damaged the connector pins. I don't know. I tried rubbing some alcohol ( disinfectant) on the connector but to no avail. Perhaps I need to replace the logic board/ motherboard?
из
if you have to replace the login board, it will be to expensive, might as well get a used one on craigslist or ebay.
из
Almost certain you will have to replace screen - avoid cheap replacement - try to get at least OEM from somebody reliable (Full OEM is preferable)
Оценка 0
1 Комментарий:
I should have tested the screen before installing so I'll never know if it's a defective screen. But I know it's not an OEM. I'll keep that in mind. Though, could this be a sign of a water damaged logic board?
из
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 6
За последние 30 дней: 6
За всё время: 297
