Laptops manufactured by Dynabook (formerly Toshiba). Toshiba has since transferred 100% ownership of the laptop business to Sharp.
1272вопросов Показать все
All USB ports not working for no reason
So i have a Toshiba laptop that i use regulary, and while i was using it a couple of days ago the mouse just stopped working. I started trying different things in the USB Ports, and none of them work, so i know it cant have just been that mouse. I hadnt pressed an odd key or anything since every key ive tried has done nothing to fix it. ive looked at tutorials all over youtube and none of them have worked. even taking the battery out doesnt work. Help? ☹
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
You Need to upgrade your usb drivers.
go on toshiba website and update them.
that should solve the issue
Был ли этот ответ полезен?
Оценка 0
5 Комментариев:
check under you laptop there should be a sticker saying model number.
https://www.toshiba.eu/innovation/downlo...
из
@blanco Every time I type all the things in it just says that they cant seem to find matching info. ive looked under my pc and it doesn't say anywhere what model number it is.
из
It doesn't say what series either.
из
@blanco nevermind, done it. Thanks so much for your help! :)
из
no problem. :) glad you have solved it
из
start by login bios check if the usb are disabled then try to do resotre your windows to date that work fine
if nothing happen you must pull out the motherboard and do the voltage test
Оценка 0
Добавьте свой ответ
no. будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 106
