Шестое поколение iPhone компании Apple, представленное 12 сентября 2012 года. Ремонт данного устройства схож с предыдущими моделями, требующий отвертки и инструменты для вскрытия. Доступен в версиях GSM или CDMA; с 16, 32 или 64 ГБ памяти; в Черном или Белом цвете.
2522вопросов Показать все
iPhone not detected and not chargin even after changing connector part
hello,
my iphone 5 was not detected and not charging anymore, I have changed the battery and it was perfectly working then, but still not charging.
Then i have decided to charge the whole block of audio jack and charging connector, i put all together again but still not detecting and not charging !
ANY SOLUTION OR CAUSE THAT YOU KNOW ABOUT THAT ?
thanks
Это хороший вопрос?
Оценка 1
Добавить комментарий
2 Ответов
have you tried a different usb cable , my iphone is very picky over charging cables , one of my cables will charge at the wall but cant use it in pc.
Был ли этот ответ полезен?
Оценка 0
There are a few things that could be wrong, you broke a prong in the lightning connector or there is just something wrong with it and it needs to be replaced. It could also be the cable, test it out with and apple cable, not some knockoff. I myself had the same problem and the problem that i had was breaking one of the prongs in the lightning connector, if thats the case for you just buy one from the ifixit store.
Оценка 0
Добавьте свой ответ
Marco Diversi будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 81
