Repair information and troubleshooting for Craftsman-brand riding lawnmowers.
mower won't start without jump
Won't start without a jump. Battery is a year old. Started fairly soon after battery replacement. A starter part was replaced (not entire starter). Immediately after shut off, mower will not start. No clicking; no attempt to turn over; nothing
Это хороший вопрос?
Счет 1
2 Комментариев
what's the question???
из
Im having the same thing with mine. Ive check all of the electrical lines and no fire to nothing. Replace silonoid,Positive cable,Checked fuse,Checked switch,did get the starter to turn over from jumping..What else could it need..It has the reverse in the ignition switch..
из
Добавить комментарий
2 Ответов
Наиболее полезный ответ
@coco10 check to make sure that your riding mower actually charges the battery. IF you can give us more information on what model your mower is and what engine your mower has, we can maybe help you further
Был ли этот ответ полезен?
Счет 3
Check the seat switch and clutch pedal switch. They must both be engaged for mower to start. I believe the Craftsman tractors also need to be in neutral. Hope that helps.
Счет 0
Добавьте свой ответ
bob clouse буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 10
За всё время: 1,824
