Why is the speed lever stuck in place?
My mixer is plugged in and will turn on if I press the quick burst button but the speed level seems to be stuck in place.
Это хороший вопрос?
Это хороший вопрос?
Not to worry, it is possible that your mixer may just need a good cleaning. If you spilled an excess of liquid onto it, it is possible that the slider has been stuck in place by the liquid. Cleaning the slider from the inside of the handle may fix this problem and allow the slider to move with ease again. If your problem persists it is possible that a piece of the slider could be missing or a part of it is caught on something inside the mixer’s handle. To fix this issue you will need to replace the mixer's speed lever, by following this speed lever replacement guide.
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 4
За всё время: 738
