Xiaomi mipad 2 totaly bricked
Hello i have xiaomi mipad 2!from a mistake i bricked it hard!no fastboot mode no recovery mode no batterie signal!!only black screen!!no pc recognition!!totally dead!i found a forun with mipad 1 bricked and they made a brigde to motherboard in the card slot!But Mi pad 2 HAS NO CARD SLOT!plz help me save my mipad 2!thnks a lot!
Update (04/09/2016)
did anyone knows the test points of motherboard xiaomi mipad 2?thnks
Это хороший вопрос?
Оценка 0
Добавить комментарий
5 Ответов
Выбранное решение
Andedcl thnks so much for your responce but how im going to do that while my pc DOESNT RECOGNIZE MIPAD 2????no signal when i plug usb!
Был ли этот ответ полезен?
Оценка 0
a hardbrick on the mi pad2 is not possible! (it's like a normal pc and haves a bios)
since the mi pad 2 haves a bios like a normal pc you need a keyboard and a usb adapter to open it also a usb hub to install windows on it (or another system to reflash the system)
http://en.miui.com/thread-243286-1-1.htm... this thread might help you
http://en.miui.com/thread-248564-1-1.htm... dual boot
Оценка 0
I have same problem... In this tutorial is only show how to flash windows 10 from otg usb... I have 16GB version of MIPAD 2 and i need to flash a MIUI ROM.... Even when i try go to DNX mode, my tablet isn't responible... Any solutions?
Оценка 0
3 Комментариев:
the way to fix it is windows (when fully broken) you could run a OS from a stick and write a copy of the partitions from a backup (someone must have a working one and do a backup that way) is the only way i know so far
из
Can you write a tutortial for me? Please!! I have bricked my MiPad for 3 months and don't have any idea how to fix it....
из
how run win by usb ?it is not turning on even pc did not recognise it?
из
Can you please let me know the EU sar value for mi pad 2?
Оценка 0
Does anyone or can anyone post pictures of their Mipad 2 default BIOS settings for the windows version please.
Оценка 0
Добавьте свой ответ
faggelosr будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 6
За последние 30 дней: 32
За всё время: 6,833
