Repair manuals and information for the Microsoft Surface line of tablets.
128вопросов Показать все
Are These Charging Contacts Burned on my Surface RT?
So this has happened, not quite sure what to do, I've ordered a new charger, but also want to know if I should be replacing the charger port? Is there someway to clean it or is it toast? I have found the instructions and parts here, I could do it, just wondering if I MUST..... The Surface RT is working but I don't want to use it until I get this sorted out, I use it daily, but have other computers, will be going through withdrawal .... All help appreciated, thanks in advance.
Это хороший вопрос?
Оценка 1
1 Комментарий
New charger arrive, the second I plugged it in I smelled burning, so I know it's not the charger, next step is replace the port and then if that doesn't work, get a new tablet ...
из
Добавить комментарий
2 Ответов
Выбранное решение
Replace the charger and clean the contacts on the tablet with some alcohol and use #0000 steel wool (very fine) to remove anything that will not come off w/ the alcohol. Make sure the tablet is off if and when you use the steel wool. You could also use a plastic bristled brush. Nothing too abrasive.
Был ли этот ответ полезен?
Оценка 1
3 Комментариев:
I have already ordered a charger and didn't want to use it until I sorted out what to do with the port. Thank you so much for the advice! :)
из
No problem. Thanks for the upvote.
из
Did the new charger alone work for this? I also experienced this issue/problem.
из
The new charger hasn't arrived yet! Bah!
Оценка 0
1 Комментарий:
Where did you order your charger from? Just wondering so I'll know not to order from there. lol
из
Добавьте свой ответ
shanonmc будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 8
За последние 30 дней: 10
За всё время: 1,301
