Samsung WB2200F 60x zoom dual grip camera released in 2014.
How do I prevent my adapter from overheating?
I am trying to figure out what can be done to prevent the adapter from over heating.
Это хороший вопрос?
Счет 1
1 Комментарий:
I was in this problem before
But i stooped use adapter
no i use SD card only
and everything right
из
Добавить комментарий
1 ответ
I had this sort of problem in the Philippines for a TV adapter. Due to the extreme heat of the country and the lack of airflow the ac adapter was overheating and the TV would turn off after a certain amount of time. So I had on of those Gel Cooling Pads for a laptop which I was not using. Mine looked like this.
http://www.amazon.com/Heat-Absorbing-Lap...
Anyway I wrapped it around the power adapter brick and rubber-banded it on.
OF course you might use something else but remember you are dealing with power so be careful.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Rachelle буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 6
За всё время: 655
