Why does the image on the display look incorrect?
There is an image on screen but it doesn't fit the monitor. It also doesn't seem to be centered.
Это хороший вопрос?
Это хороший вопрос?
The first thing you should do is ensure the computer is outputting an image that is the same size as the display. This can be done by right clicking on the desktop and selecting "Display Settings". From there select "advanced options" and set the resolution to what is recommended (This should be 1680x1050).
If that doesn't work try calibrating the monitor by pressing the menu button on the bottom left corner and using the "+", "-", and "Select" buttons to start the "auto" function. This should center and size the display on the device.
Был ли этот ответ полезен?
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 53
