Broken Charger Pin DC-in board
Hello,
My charger pin broke off inside my laptop. I have tried tweezers, and have had zero success.
Anything else I can try would be greatly appreciated.
thank you so much,
Kristi
Это хороший вопрос?
Hello,
thank you so much,
Kristi
Это хороший вопрос?
Open it up and remove the DC-IN port. Pull the center brace on the back of the DC-IN port out slightly. This will allow access to the broken pin.
Here's how to get to it:
PowerBook G4 Aluminum 15" 1.67 GHz DC & Sound Card Replacement
Был ли этот ответ полезен?
Power off and battery removed. I would screw a small screw into the part stuck in the computer and then remove it carefully with a pair of pliers pulling on the screw head. Good luck.
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 4
За всё время: 2,281
