Samsung Galaxy Note 10.1 stuck in reboot cycle
plss fix this samsung galaxy note 10.1
Это хороший вопрос?
Это хороший вопрос?
Have you tried pushing the power and volume up buttons together or the power and the volume down to power down the device? If it is off you could then either try to start it normally or try to flash a new ROM onto the device.
Был ли этот ответ полезен?
I would take out the battery and then put the battery back in, but if it is an internal battery like an apple product you might have to get the battery to turn off fully until it will not even turn on then charge it and turn it on and hope for the best.
i try it but didnt work
You might have to reset to factory default to see if that fixes the reboot cycle.
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 366
2 Комментариев
why i cant fix
из Adam Matthew
it was stuck in reboot cycle plss fix
из Adam Matthew
