no water comes out from the brewer head
For my machine, it even stopped making sound, of cause no water comes out from the brewer head. What could this mean? a broken pump?
Cheers,
Jin
Это хороший вопрос?
Cheers,
Jin
Это хороший вопрос?
If the machine has power (heats, lights come on) but the pump doesn't make a sound when either the coffee button is pressed or the steam knob is turned, then yes it's possible the pump is completely dead. This is very rare though so I would make sure to check all the wiring and ensure the pump is getting power.
Был ли этот ответ полезен?
Pump does make sound, but nothing comes out. Steam wand works fine.
Thermal fuse which on the white wire may be blowed, use ohm meter to check,
За последние 24часов: 3
За последние 7 дней: 6
За последние 30 дней: 7
За всё время: 703
1 Комментарий
Mine has this issue and the pump labors to work. No water comes out.
из Javagirrl
