Samsung Galaxy S7 (SM-G930, SM-G935) — смартфон седьмого поколения линейки Galaxy S, анонсированный компанией Samsung Electronics 21 февраля 2016 года на MWC в Барселоне[
369вопросов Показать все
Can you fix an camera lens of a samsung gs7 edge?
Это хороший вопрос?
Оценка 1
Добавить комментарий
2 Ответов
is it the just the glass that covers the camera or the lens on the camera itself, if its just the glass piece you can replace it by replacing this piece http://www.ebay.co.uk/itm/OEM-Replacemen...
just be careful you don't break the back taking it off,once youve gotten the back glass back off all you have to do is pop the broken one out and adhesive the new one on , otherwise you can replace that back camera however the parts are pretty scarce you'll be able to get it but itll be around 20 quid as of right now or you can wait until the parts actually being produced rather than just taken from other s7's and it'll be a bit cheaper, if there's anything i didn't explain just reply
Был ли этот ответ полезен?
Оценка 0
if broken part is the just the glass that covers the camera or the lens on the camera itself, if its just the glass piece you can replace it by replacing it you can by under this link
 https://www.sunsky-online.com/ko/
Оценка 0
Добавьте свой ответ
Josh Cusinato будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 4,720
