The Samsung Galaxy Tab 2 10.1 is a 10.1-inch Android-based tablet computer and belongs to the second generation of the Samsung Galaxy Tab series.
133вопросов Показать все
Why is my screen not displaying images?
My tablet hasn't been turned on in a while. I go to turn it on and the screen boots up to a gray screen but doesn't show the Samsung logo or anything, just gray. The screen appears to have a brighter gray along the border but nothing actually loads. It may also be important to note that the boot-up sound does go off when I attempt to turn it on just by holding in the power button.
Also when I try plugging it into my PC I get a message saying that the device malfunctioned and then the device promptly disconnects from the PC. I'm not sure the cause for either error.
Это хороший вопрос?
Оценка 1
2 Комментариев
My screen won't turn on at all so I am not able to do that set of commands since I wouldn't know when to release the buttons. I feel as though the screen is dead but I'm not sure since I've never seen a dead screen before
из
check battery voltage 1st if its holding a charge...if its good...check the lcd flex the connects the lcd to the board...
из
Добавить комментарий
2 Ответов
Наиболее полезный ответ
'Reboot your tablet into recovery mode and factory restoreit
Hold 'vol down' and 'power' buttons on tablet
Release 'power' when samsung image is shown
Release 'vol down' when the two icons are shown
Use the 'vol down' to navigate between the icons
Highlight the left icon (box)
Press the 'vol up' to select it and boot into recovery mode
after this using the volume keys go to factory data reset, and scroll to yes and allow up to 10 mins for a factory reset
this should fix the problem'
Был ли этот ответ полезен?
Оценка 1
it wont show screen up
Оценка 0
Добавьте свой ответ
piratespride будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 11
За всё время: 896
