The Zebra GK420d is a direct thermal label printer for desktop use.
3вопросов Показать все
zebra gk420d printer indicator light flashes red and green
zebra GK420d printer indicator light flashes red and green and printer does not print
is there a reset button or what would be the fault?
Это хороший вопрос?
Оценка 2
Добавить комментарий
4 Ответов
Выбранное решение
Error 8 Alternate Green Red FLASH memory is not programmed.
Return the printer to an authorized reseller.
Error 9 Red and Red Green The printhead or motor has had a critical failure.
Status Indicator Reference
A complete list of status light indicators for the GK series printers can be found here:
https://km.zebra.com/kb/index?page=conte...
Был ли этот ответ полезен?
Оценка 4
Thank you, with your help I was managed to repair my gk420d. Fixed the rfid lamp.
Morten
Оценка 0
4 Комментариев:
Can you explain how you solved it? Many thanks
из
Morten, can you give details of your fix?
Thx
из
Morten can you please explain how you fixed the rfid lamp?
из
Good evening!
The flash memory S29AL032 has inconsistent data, you must unsolder the memory, erase, program and resolder on the main board.It is service for technicians.
из
Please give details I have the same problem
Оценка 0
Please delete this thread from the internet immediately since the unhelpful information it contains keeps coming up in my google searches!!! PLEASE DO THIS IMMEDIATELY!!!!
Оценка 0
Добавьте свой ответ
brian будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 32
За последние 30 дней: 106
За всё время: 19,193
