Компания Apple представила iPhone 5c 10 сентября 2013 года. Ремонт данного устройства схож с предыдущими моделями, требующий отвертки и инструменты для вскрытия. Доступен в версиях GSM или CDMA; с 8, 16 или 32 ГБ памяти; в цветах: Белый, Розовый, Жёлтый, Синий и Зелёный.
1233вопросов Показать все
Black screen but power is on.
Hi,
The screen on my daughter's phone won't light up. I'm able to restore the phone when connected to my macbook, so, it's powered on. That did not fix the problem. I opened it to ensure the connections were all secure and that did not fix the problem. One thing that is odd is that the phone does not vibrate or ping when plugged in. This leads me to believe it's something other than just a bad screen. Any thoughts?
Thanks.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
This is caused when a wire becomes loose. A display flex cable may have been unplugged
To fix this, unplug the iPhone and open it up
On the bottom right there should be a long metal plate with 2 screws in it
Remove the screws and unplug the flex cable
This is the battery
Now do the same to the display flex cables.
Now plug in the Display flex cables only and secure the base plate to the display flex wires
After that go ahead and reconnect the battery
DO NOT POWER IN THE DEVICE YET
now put the plate back on the battery flex cable and carefully close the phone back up
Now try to power it on
TaDa! You should be powered on!
Был ли этот ответ полезен?
Оценка 0
5 Комментариев:
Hey Jake,
Thanks for your comment. I wasn't particularly detailed in describing what I did when opening the phone, but, this is essentially what I did and no luck. I'm thinking something else is going on since there's no sound and no vibration when I connect a usb cable.
из
I had this same issue while replacing my iPhone 5c screen and this fixed it for me
Try that but instead only unplug the battery
из
Did you experience the same issue where the phone was definitely on, but, it would not vibrate make sound in addition to the black screen?
из
Yes...not sure why this happens
из
I gave it a try just unplugging the battery first. No luck. Then, tried both the battery and the screen. Again no luck.
из
Добавьте свой ответ
jeremymayes будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 99
