Repair and support for the controllers that shipped with the PS3. Released in November 2007 (Japan only) and 2008 (other countries), the six-axis lithium battery powered controller (CECHZC2) is straightforward to repair.
157вопросов Показать все
Why does my controller randomly presses buttons?
Whenever I play a game the controller justs starts choosing options that match the buttons out of nowhere without them being pressed. For Example I'll play call of duty and all of the sudden I'll start switching weapons or shooting without me pressing the button.
Это хороший вопрос?
Оценка 28
14 Комментариев
Only difference with mine is it works normally on the charger as a wired controller why would this happen
из
Best guess is that your Bluetooth module is giving out wonky signals. Does it happen with other controllers?
из
As for mine, the controller works fine on another person's computer when I try but starts pressing itself randomly on mine
из
What I usually do is smack it against the floor until it works properly
из
I had the same problem. I then opened up my controller and cleaned the contacts. check this guide here: http://bit.ly/openps3controller
из
Показать 9 больше комментариев
Добавить комментарий
8 Ответов
Выбранное решение
I would suggest you open up your controller and clean the contacts. If things get stuck in there or if its grounding out for some reason across the contacts you'll get the behavior as described.
Use this guide to help you open it up.
P.S. the clear contact sheet that the buttons press on shouldn't be bent or crinkled.
Hope this helps.
Был ли этот ответ полезен?
Оценка 17
5 Комментариев:
Thanks alot! It worked great!
из
Hooray! Glad to help. :)
из
из
My problem is when i try to remove the five 7.2 mm Philips screw, one of them got stuck and i couldn't remove the cover of the controller, pls help
из
But what if the same buttons are not functioning across all my controllers 4 plus so far the left and up d-pad buttons and I'm also getting the call of duty Black ops when I pull a grenade 3/4 of the time it just holds on to the grenade after pulling the PIN and it just explodes in my hand no matter if I'm manically smashing buttons or put down the controller and press nothing I just recently cleaned out the dust took it apart cleaned the lens and put it back together because it wouldn't read discs now it works perfectly other than this issue
из
I had the same problem. My controller randomly sent d-pad signals.
The fix was to thicken the contact foam that is pushing the contact strype against the board.
I just used some transparent tape.
Here's a video from someone on YouTube.
https://www.youtube.com/watch?v=cY4rLTpn...
Оценка 6
What if the clear contact sheet is bent or crinkled?
Оценка 0
the clear contact is the sensor and if that is dirty or bent it will screw the hole things up making the controller user
Оценка 0
In some cases, it could simply be the casing.
In my case, at the top left just below indicator number 4, there is a small piece of plastic that snaps the controller together.
Being I got mine used, it has obviously seen previous repair and the previous owner damaged this plastic contact.
By opening up the base and carefully pushing this piece back in position with a flat head, the controller snapped properly in place. After screwing it back together tightly (the screws were also loose compared to factory) I resolved my phantom D-Pad issue.
I also resolved improper placement of the R2 trigger spring in the process XD
Оценка 0
hopefully this works my PS3 controller isn't working very well it keeps pressing random buttons and it keep moving around by its self and its also really difficult to shoot in GTA and Call of Duty.
Оценка 0
1 Комментарий:
Let us know. I'd be interested to hear if you find out new information about it!
из
hope this works too my controller make vehicles like motorcycles swerve left or right in GTA 5 so it makes me mad. I've only had this controller for 1 year and same for play station.
Оценка 0
1 Комментарий:
Go to settings and turn off Motion Sensor for Bike.
That should fix the swerving
из
When i press the x button on my p3 controller the button gets struck in , same with my R2 button …..how do i resolve my problem.
Оценка 0
1 Комментарий:
My ps3 controller keeps pressing random buttons and how do I fix that without opening the controller
из
Добавьте свой ответ
Rasheen Barber будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 27
За последние 7 дней: 186
За последние 30 дней: 867
За всё время: 265,952
