The third generation of the Samsung Galaxy Note phablet series released September 25, 2013. Identifiable by the model number N9005.
What died on my phone?
My phone fell in water and I switched it on the first time and it showed an Android sign which was telling me not to switch off my phone but I removed the battery anywhere and switched it on again and this time it went on and then switched off itself.now it's not switching on.i tried blowing it but it didn't switch on and it's still not switching on until now.please help I want to know what's wrong
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (2)
Выбранное решение
tmutamaenda the biggest issue to worry about is the water damage. Anytime you try to charge, sync or start it you are increasing the chance of a short circuit. Keep the battery out of it and fix the water damage first.
If you do not have access to an ultrasonic cleaner, I suggest you get some 90%+ isopropyl alcohol and a soft brush. Disassemble your Note by using these guides Clean your board and all the other parts with it. Use this guide to see how to properly clean it. It was written for an iPhone but all the points a re still pertinent to yours as well. Remove all the EMI shields to clean under there as well. Once you have it cleaned, check all the components on the board. Make sure none are missing, or otherwise damaged. Make sure all the cable ends and connectors are also cleaned. Then reassemble, replace the battery and re-evaluate.
Был ли этот ответ полезен?
Оценка 4
Have you tried the recovery option?
The link below will show you how to put the device into recovery mode which may get it working
http://www.digitaltrends.com/mobile/use-...
Оценка 1
Добавьте свой ответ
tmutamaenda будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 93
