4 inch display / Available in a variety of colors / Released in 3 different models / 16, 32, or 64 GB capacity
331вопросов Показать все
Home button not working after a drop...
I have a 5th gen iPod here that the guy dropped it and the home button stopped working, if you pull the screen off and manually push the button on the flex cable it works, but the home button itself will not actuate it at all.
Any ideas?
Это хороший вопрос?
Оценка 0
2 Комментариев:
sunruh sounds like a iPod touch 5th gen, or is it a Classic?
из
@oldturkey03 It is a touch, I should have said that.
из
Добавить комментарий
1 ответ
There could be a possibility that part of the button located on the flex cable got damaged. Whereas you said it responds if you push the button on flex cable, I would verify the small black post located dead center is still intact. If not, a new flex cable assembly may be required shortly as that helps guide and maintain its function for shorting type of circuit that it is. If it is intact and not damaged the bracket that it is adhered to may have gotten bent down during the drop causing to large of a gap for the home key to make contact. With out risking damaging anything, sometimes the easiest fix is 1 or 2 small cut squares (no bigger than the button on the cable)of something like electrical tape on the button itself or in the center of the homekey. Best of luck and let me know how it works out if you haven't already done something about it.
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
@dewales Thank you for your reply. I put it back together as it was and it works just as bad as it did before and after a while the client said forget about it and used it as it was .
из
Добавьте свой ответ
sunruh будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 86
