Announced in March 2015, and released April 10, 2015, the Galaxy S6 is the next flagship in the Galaxy line. The curved screen version is known as the Galaxy S6 Edge.
487вопросов Показать все
S6 edge battery on S6 Flat
Hello, my batterylife on my Galaxy s6 is slowly getting worse and im going to order a new battery to replace it, but i was wondering could i cram in the S6 edge battery on the S6 flat? Becuase the s6 edge battery has a 50mah+ with a total of 2600mah and the s6 flat 2550mah.
Thank you.
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Выбранное решение
The batteries are not interchangeable with each other. The connector on both phones are placed in a different area on the motherboard which will not work.
Был ли этот ответ полезен?
Оценка 1
2 Комментариев:
Thank you for the quick answer :)
из
Your welcome.
из
Is the connector the same? Would it be acceptable to use a different battery for testing only?
Оценка 0
Добавьте свой ответ
Delshad будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 9
За всё время: 1,584
