Второе поколение iPhone. Модель A1241; 8 или 16 ГБ памяти; с черной или белой задней пластиковой крышкой. Ремонт проще, чем первого iPhone. Требует отвертки и инструментов для вскрытия.
1158вопросов Показать все
Ear peice and proximity sensor not working
I replaced the headphone jack on my iPhone because I was not getting a good connection to various headphones. In putting it back together I must have not connected connector 3 correctly. I have tried a number of times to reconnect it. Does anyone have a photo of what it should look like or any suggestions as to what I may be doing wrong? If not what is my next step?
Это хороший вопрос?
Оценка 1
Добавить комментарий
5 Ответов
Выбранное решение
Could be your connector? It is hard to notice, but sometimes they break and lift off the board slightly.
http://hectordtruong.blogspot.com/
Был ли этот ответ полезен?
Оценка 0
Наиболее полезный ответ
Here's a pic (the model in the pic is a 3GS, but the connector is the same in this instance):
It has a gold tip that should be completely in the connector. Make sure the locking bar is down once the gold tip is in there.
Have you tried restoring it, or can you not get that far?
If that doesn't fix the problem, it seems that the front panel/digitizer is broken.
If THAT doesn't fix the problem, all signs point to logic board.
Оценка 2
1 Комментарий:
I Must have knicked the #3 cable while putting it back together. I too purchased a new cable, and although it is not the easiest thing to replace I did do it and now everything works wonderfully.
Оценка 2
3 Комментариев:
+great! now you can accept your own answer
из
+ (You forgot your tick pollytintop)
из
oops, thought it went on.
из
Might not be the logic board. That ribbon cable is fickle. I ahd this problem and just bought the cable (proximity sensor cable) off of amazon and replaced it. There's a youtube video on how to do it (since it's not immediately obvious), and it's an easy repair.
Also, remember to always shut off your phone before you open it. Seems that the proximity sensor or the cable may be especially sensitive to that.
Оценка 1
1 Комментарий:
dam im such an idiot i was trying to lift the white part of the connector and not the black thing and i then chipped abit of the white part but it has not tottally fallen off and the ribbon still fits in there thankfully but i guess its damaged and now i know how to fix it properly
Оценка 0
Добавьте свой ответ
Scott будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 4
За последние 30 дней: 6
За всё время: 7,897
