Guides for the Wi-Fi version of the iPad Mini 3 (A1599). Announced on October 16, 2014, the iPad Mini 3 is the successor to the iPad Mini Retina (now known as the iPad mini 2).
Вопросов 20 Показать все
Is the charge port on an iPad mini 3 replaceable?
Is it possible to change the charging port on an iPad mini 3? The steps in the disassembly process and it looks like it is tied to the motherboard...I don't want to take the whole thing apart if its not possible.
Thanks in advance!
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (1)
Yes the charging port can be replace but it's soldered to the motherboard. so you will need soldering skills to do the repair. The charging ports very seldom goes bad, so unless you have damage to the charging port it may not be the charging port giving your problem, but a chip on the motherboard.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
vbgagnon будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 1,043
