Does this charges has auto shutdown?What kind of protection has it?
I am waiting for this charger the next week and i would like to ask, can i leave it permanently connected even when i am not charging anything? Does this affect the charger? Secondly does it have overcharge and short circuit protection?
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
that is a simple 12v to 5v regulator. It will supply its rated current to anything connected, the same as charging from you computer port. It is up to the device to control its charge. You can leave it plugged in to the power port of your auto as long as the port is not connected directly to your battery. If it is it will eventually run down your battery as it does consume some power even with nothing plugged into it.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
NIKOLOPOULOS THEODOROS будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 8
За последние 30 дней: 9
За всё время: 278
