Repair guides and support for 20" Intel iMacs by Apple.
892вопросов Показать все
Install Snow Leopard on 20" iMac without optical drive
I upgraded from Snow Leopard to Mavericks to Yosemite on 20" iMac.
The device is functioning unbearably slow.
I have the snow leopard DVD that came with the computer. But the optical drive is not working on it anymore.
The optical drive is not available as the product now is obsolete.
I attempted to install from recovery partition, it did not work as there seems no recovery options when I boot to that window using Ctrl+R.
Living in an area where I cannot arrange for another apple computer or laptop so I could install OS via another apple drive.
The only option left is to copy the contents of DVD to a USB and install from it.
However, not sure how I can achieve that. Need help!.
Это хороший вопрос?
Оценка 0
1 Комментарий:
Exactly which 20" iMac do you have?
из
Добавить комментарий
2 Ответов
Use an external CD drive from walmart or use disk utlity to make a bootable Usb
Был ли этот ответ полезен?
Оценка 0
Try Command-Option-R instead of the regular Command-R, this should launch Internet Recovery and you'll be able to reinstall Snow Leopard over the internet without the use of a DVD or USB drive.
Оценка 0
Добавьте свой ответ
fkqrf будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 3
За всё время: 57
