My HE3 has a f02 error code. What does it mean?
I have an f02 error code on my he3 kenmore washer what does it mean?
Это хороший вопрос?
Это хороший вопрос?
F/02
Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
Check the drain hose and make sure it is not plugged or kinked.
Check the electrical connections at the pump and make sure the pump is running.
Check the drain pump filter for foreign objects.
If the above does not correct the problem, replace the pump.
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 4,367
