The wi-fi only version of Apple's iPad Air, model number A1474. Available in Space Gray or Silver, it packs the custom A7 processor and ships in 16, 32, 64, and 128 GB configurations.
299вопросов Показать все
Home button zif connector lock broken
I recently cracked the glass screen on my ipad Air, and bought a new replacement part.
I had no trouble getting the screen off, except for an issue with the zif connector for the home button ribbon cable (the connector that sits just in the corner of where the screen cables are connected).
Apparently the ribbon cable is locked into place on the zif connector with a small plastic "lock" (can't remember the word for it), and it seems I accidentally broke that plastic piece off when disassembling my Ipad, so now i can't properly connect the home button of my new screen in place.
Is there anything i can do to fix it in place? I'd try some tape if it wasn't because the cable has to be firmly connected, and i doubt tape would do that :)
Это хороший вопрос?
Оценка 2
Добавить комментарий
1 ответ
Выбранное решение
Try this
[связанный продукт отсутствует или отключен: IF145-171]
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Azra будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 11
За всё время: 1,564
