Where is the external reset button on the tablet?
Brand new tablet was working fine but I disconnected from docking station and screen went blank. I can tell power is on and when plugged back into the soft docking station and I turn the caps lock button on the lite indicating caps lock turns on. Nothing on screen. manual says to press a pin into the hole to reset. me and my son examined and no hole can be found. Someone said next to audio connector but there is non on this model. Has Windows 10,
Это хороший вопрос?
Оценка 2
1 Комментарий
I have a Spring 8 HEXA tablet, i think it is in Boot Loop mode and i can't get it to turn on and my keyboard want come on also, what can I do to fix the problem
из
Добавить комментарий
6 Ответов
Наиболее полезный ответ
Hi
You need to hold the "Power" & "Volume" up (+) buttons simultaneously for 20 seconds until the penguin image appears in the upper right hand corner. 4. Once this image appears release the "Power" button while continuing to hold the "Volume" up (+) button. 5. After a few seconds an image of an Android on his back will appear. Once this image is visible, press the "Power", "Volume up (+) & "Volume down (-) buttons simultaneously...only once. 6. Next your device will go into "Recovery Mode", use the "Volume" up & down buttons to navigate the parameter. 7. Scroll down the list of options and use the "Power" button to select "Reboot System"
reset buttons dont work no more if its android!
happy pressing ;-)
Ray
Был ли этот ответ полезен?
Оценка 4
3 Комментариев:
he said, has window not android, jesus!!!!
из
This worked great thanks!
из
Even though he said android it still works on the windows 8.1 tablet. I am so happy that my tablet works again thank you soooo much.
из
I have the Windows 10 eMatic EWT935DK, and it will no longer boot into Windows. It was at the login screen for the PIN and I could not enter it because the docked keyboard doesn’t work and the touch is mapped incorrectly on the screen. rebooting got it to attempt startup repair, and it failed, repeatedly. Attempting to boot from a Win10 USB drive with no luck. I held down all 3 buttons and got to a screen with options of - “Continue”, “Boot Manager”, “Device Management”, “Boot From File”, “Secure Boot Option”, and “SCU”. All were under blue/white icons. “Continue” and “Boot From File” flash when I use the volume up or down button to change between them. I can’t seem to select any other icons and I don’t know how to enter as the power button does nothing until it is held for some where around 10 seconds, then the device powers off.
Оценка 1
This wasnt my workings but it was from another guy “Botch Job Ray“ i am just reposting it becuase it was very helpful. Also even though it says android it still works for windows 8.1. If you follow the directions exactly it is sure to work.
Оценка 1
My EWT935DK came from factory with W10-32 on it. There is no penguin logo displayed anywhere, anytime which is not surprising. The Penguin icon belongs to LINUX of which ANDROID is based. There is no reset hole next to headphone jack or anywhere else. An ANDROID style reset ..... volume + and pwr does not work on my device. Simply works just like pwr only does.
So, it would be great if someone knows how to do a factory reset for this specific device. Ematic's user guide says there is a reset hole .... there is not. Their tech support is non existant.
Оценка 1
I have tried everything. Nothing works
Model# EWT935DK
1-NO RESET BUTTON.
2-HOLDING DOWN VOL. BUTTONS THEN/AND POWER IS A BIG WASTE OF TIME
THERE GOES ANOTHER 125$ DOWN THE DRAIN.
NEVER AGAIN WILL I BUY SUCH A POS!
VERY !#^&@@ OFF!
Оценка 0
My tablet stays on the ematic powered by Android screen
Оценка 0
Добавьте свой ответ
wbfox1978 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 15
За последние 30 дней: 21
За всё время: 9,188
