Screen only shows gray and black lines?
My Tab only displays black and gray vertical lines, but I can hear that the unit is powered on, what might be the problem? Is it repairable? Thank you!
Это хороший вопрос?
Это хороший вопрос?
Looks like the LCD for this went bad or became loose from the board itself. It is definitively repairable, but I do recommend that you purchase the LCD and Digitizer assembly if you are going to do this yourself.
Был ли этот ответ полезен?
I had the same problem replaced the screen and digitizer and still it's black with gray lines
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 4
За всё время: 749
