The Nikon Coolpix S33 Waterproof Digital Camera B00T85PKD0 is designed as an all purpose camera that is waterproof, shockproof, and freeze-proof.
17вопросов Показать все
2 Pictures with different colors?
Each time I take a picture it takes 2 pictures instead with one being the actual color and the second being lighter or overexposed. How do I fix it so it only takes one picture at a time that is the actual color?
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
I had this same issue. I would recommend downloading the "Reference Guide" for this model from Nikon's website. ( http://downloadcenter.nikonimglib.com/en... )
It contains more detailed instructions than the "User's Guide" does. Specifically, check out page 29 under the heading "Shooting Back-lit Scenes". The behaviour you have described is completely normal if the camera has been set to this mode. The manual gives detail on how to change from this mode, as well.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Anne будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 4
За всё время: 139
