Дата выхода 19 сентября 2014 года. Это маленькая версия iPhone 6 Plus с 4.7-дюймовым экраном.
4994вопросов Показать все
No response from phone even with different components
phone was left to me by a customer was dropped on the floor said the lcd was sending lines through... . OK so first tried to plug it in and hard reset it no response. tried new screen new battery and charge port (and plugging it in to power on). NO response. using a test phone i tried the customers screen to see the damage, it came on briefly through my test phone( with no damage) and shut its self off, not sure why. But Im only left thinking the mother board is the problem. If anyone else has a suggestion for this loop i seem to be stuck in that would be AMAZING! Thanks >v<
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
I would check to see if the backlight pins are shorted,this will cause the screen to shut off. Also when you say the screen shut off, is only the backLight shut off or the LCD too?
Был ли этот ответ полезен?
Оценка 0
2 Комментариев:
the whole lcd i do not see anything from the screen even without the back light Im more then frustrated , I am lost
из
Try shining a light at the screen and see if you see anything. I mean that the backlight may be nonfunctional, but the LCD is still displaying something too dark to see because of the nonfunctional backlight.
из
Добавьте свой ответ
Veronica Royal будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 61
