iPod Classic 6th Generation. Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
894вопросов Показать все
Need to format, but not recognized by computers.
Hi folks,
I had some problems with my iPod so I decided I wanted to format it. Problem is iTunes and Windows Explorer freeze up when I connect my iPod. I put it in disk mode, but same problem. I put it in dfu mode and it shows a message it needs to be restored via iTunes, BUT as I've mentioned iTunes freezes up when I connect my iPod.
Can anyone please help me? I can't explain how important it is for me to have music with me on the go. Those who feel the same, understand immediately what I'm talking about.
Thanks so much for your time and attention.
Paul
Это хороший вопрос?
Оценка 3
1 Комментарий
I don't have an answer but I have the exact same issue. Hopefully another drop in the bucket yields an answer. . .
из
Добавить комментарий
2 Ответов
Наиболее полезный ответ
paulmeijer I'd start of by putting the iPod in Diagnostic mode. Check on here how to do that.
Check the results from your diagnostics and let us know what it says. Right now my number 1 suspect for this is a bad hard drive and the logic board a close 2nd
Был ли этот ответ полезен?
Оценка 2
every time I try and do the test it stops at the firewire part all other tests pass but gets stopped at this one. don't even know what the firewire is
Оценка 0
1 Комментарий:
Hard reset and reinstall ITunes
Your music should be replaced
из
Добавьте свой ответ
paulmeijer будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 564
