Htc m8 Power bank issue
Does power bank cause any problem to my m8? Will it decrease the efficiency of my phone battery? If not then which brand power bank can i use for my m8. Please suggest me.
Это хороший вопрос?
Это хороший вопрос?
Your phone will not be damaged by using power bank unless you Pay attention to these...
--Before going to shop u should read whats power output written on your phones stock power adaptor, its usually 5volts 1.0amps for a mobile device (check)
So you need a power bank with same output... (5v 1a i mean)(5v 2ampers for faster charge ,may harm device in long terms of use)
The brand does not really matter since there are lot of fake chinese in the market...
--You need a capacity around 3500mah to perform 1 full charge on htc m8 or higher capacity for longer usage (more cycles)i recommend 5000mah
--a power bank with capacity indicator led is ideal because it says there are safety chips in it(99%)and because power banks are batteries (dc) they are not as dangerous as crappy wall adaptors
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 439
1 Комментарий
Thank u for ur suggetion. One more question. In market you know so many power bank of different brand. So, which brand can i use in this case?
из Fazlul Azim
