How To fix Lumia 735 SD Card errors...
Drop my Lumia 735 several times and start showing SD card errors, looking all over the web and replacing SD card just wouldn't works ...
Это хороший вопрос?
Это хороший вопрос?
Finally I decided to open it up. You need a torx screw driver and a plastic tab. To take apart the Nokia Lumia 735, just follow the video instructions here https://www.youtube.com/watch?v=yLCwTk4D....
The culprit is the ribbon cable connection. Just take apart the phone and reseat the ribbon cable connector tightly between the front screen assembly and the back cpu assembly will solve the problem.
Apparently every time you drop the phone, it loosen the connection lightly. after several drop, the SD Card error show up and asked you to fix bit it will never work. Swapping card wouldn't work ether.
Hope this help everyone that encounter similar problem : )
Был ли этот ответ полезен?
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 680
