Guides for the Wi-Fi version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
220вопросов Показать все
Back-light fuse pops as soon as the battery is connected.
I received an iPad with a back light issue. usually i would pin it down to the fuse/filter. but every time the fuse is replaced i see a puff of smoke come from it as soon as the battery is connected. I have additionally replaced the IC/diode and the coil (I know its not the coil... but still). has anyone else encountered this if so is there a solution.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Check the camera IC's. I had a heck of a problem with iPad Mini 1st gens popping filters and it ended up being a bad camera IC. I was popping them when I disconnected the screen and didn't figure it out until it was too late.
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
hmm ok. i will check if i can find the camera ic. although i can't see how the back-light would be connected to the camera.
из
Добавьте свой ответ
Thomas Edwards будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 12
За последние 30 дней: 12
За всё время: 91
