Dualshock 4 only works in PS4 safe mode?
I'm having problems with my Dualshock 4 controller.
If it's not plugged in with the USB cable, it does nothing. No lights when I press the PS button.
When I turn on the console, it says connect the controller with the USB cable and press the PS button. When I do that, nothing happens. No lights on the controller and no response from the PS4.
However, when I turn on the console in safe mode, the controller seems to work just fine.
When I try to connect the controller to my PC with the USB cable, it continually disconnects and reconnects.
I have tried 3 different USB cables, including the one it came with. This is the controller that came with the console.
What can I do?
Это хороший вопрос?
have you found a solution for that mate ? because I have this issue too
из Abdullah
