The HTC One (codenamed M7) is HTC's 2013 flagship smartphone. It features a seamlessly designed unibody aluminum frame, large dual front-facing speakers, and a 4.7-inch 1080p display.
HTC One M7 Completely Dead, possible fix
HTC One M7 ( PN0731).
Not sure what happened to it, but there is no charge, no connect nothing through USB, no Boot, not even a little red light when plugged in. No JTAG, since no power to the board it seems.
Scratching my head to figure out why, cant come up with any reason for such a complete failure. So examined it with microscope.
Found one component that might be the problem.
Location on Board:
[IMG]https://s32.postimg.org/zfdg46fp1/S20160...[/IMG]
Zooming in you can see that there is an IC that is cracked
[IMG]https://s32.postimg.org/cam566ff9/S20160...[/IMG]
What I'm looking for is help with 3 things:
1. Do you think this is the problem?
2. What is this component? It has an code (PAY 328), but I have no idea what that symbol in the top right corner is, so no idea how to look it up.
3. If not that, any ideas? I'm mostly concerned about data recovery, not making the device work again, so if anyone has ISP pinouts that might be a way to go
Это хороший вопрос?
Счет 4
Добавить комментарий
1 ответ
Наиболее полезный ответ
press power with down volume .if is not go to bootloaderthen you shoud check a new battery .
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
james буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 6
За всё время: 4,447
