The third generation of the Samsung Galaxy Note phablet series released September 25, 2013. Identifiable by the model number N9005.
248вопросов Показать все
No charging after get wet
My phone dropped in the water about 1 week ago. Soon I opened it and dried with cold hairdryer the mater board and all the contacts. After 3 4 hours a tried to switch on and it worked fine. After about 3 days during the night the phone switched off. I did not know why. When I tried to charge it the phone showed the dock was connected but did not charge the battery. So I bought and replaced a new dock charge inside the phone but remained the same problem. Moreover at the time no more signals that the charger is connected. What can I do now? Thank you for your reply!!! I apologise for my bad English.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Depending on how long it was in the water and how deep the water was, water could have gone in through the charging port. Either the battery or the wiring that goes to it is probably damaged.
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
Thank you very much. The phone has been in 1 cm of water for about 10 seconds and I dried it very well. Now all the charging dock is new (inside the phone connected to the mother board) but not charge. Maybe is damaged the power ic? Could I change it? How?
из
Добавьте свой ответ
olrac itama будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 526
