husvarna tractor will not alow cutter to be inguaged engine cuts out
engine cuts out when trying to to engage cutter
Это хороший вопрос?
Это хороший вопрос?
What kind of fuel does it use? I have similar problems but with a weed eater, if the fuel is the kind that you have to mix yourself you may have used the wrong ratio. In this case check the spark plugs to see if it is running rich or not, then remix the fuel according to manual. I have limited experience with tractors but I really hope this helps you!!
Был ли этот ответ полезен?
Ann, Ann, motors problems are obviously not your specialty, sorry.
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 31
martynryan1950 what model is your Husqvarna tractor? Sounds like a safety switch issue
из oldturkey03
