Repair and disassembly guides for Brother printers.
352вопросов Показать все
it wont print on paper
can u help me with a problem, my brother mfc- 255 it wont print on paper.. it work properly but no ink on paper, if i look close i see dots on paper that it was trying to print but i dont know how it is not printing on paper can u help me with this problem ?
Это хороший вопрос?
Оценка 0
1 Комментарий
Maybe it was offline
Open the printers’ ‘start’ menu and click on ‘control panel’ and tap on ‘printers and faxes’ icon. This sequence of moves will open up a new window and a list of printers will appear. The list includes all the printers currently setup on the serving computer.
Double click on the icon of the printer if the user wants to reconnect online. A pop-up window will then appear, this consist of details of all current print jobs scheduled on the printer.
And last, go to ‘printer’ in the menu window and tap ‘use printer offline’ and automatically this action will reconnect the printer ‘online’ from the ‘offline’ status.
из
Добавить комментарий
4 Ответов
Выбранное решение
Junior I'd start with cleaning the print head. This video should help. Different model same idea
Был ли этот ответ полезен?
Оценка 1
Let’s try these options to fix the problem.
  • Power off your printer for one minute and power it back on.
  • Now reconnect your printer to the computer.
  • Check the ink label.
  • Cancel all print jobs and make a new print. I am sure, it will start working.
  • If it is still not working, you need to go visit: brother printer says offline and follow the instructions to fix the problem.
Оценка 1
Nozzle Cleaning on Printers With Touchscreens
1. Tap the touchscreen's "Ink" button or ink indicator.
2. Touch the "Cleaning" option.
3. Touch either "Black," "Color" or "All" to clean the black nozzle, a single color nozzle or all four nozzles, respectively.
4. Wait for the printer to finish cleaning the print head. When done, it returns to its Ready mode where you can either print or generate a Print Quality Check Sheet to see if the cleaning was successful. If it was not, repeat this process three more times.
Оценка 0
I think there is an problem with ink.
Maybe the nozzles get chocked Or ink tank is empty.
but if its about inks
then go for the solutions given here:
Brother printer offline
Brother control center
Brother printer wifi setup
Оценка 0
Добавьте свой ответ
Junior будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 3
За всё время: 459
