The third generation of the Toyota Camry in all markets outside Japan. 1991-1996 was also called the XV10 series of Camry vehicles.
79вопросов Показать все
New AC compressor now overheating. Help!
I have a 96 Camry V6 3.0 I bought for 400 dollars. But the car has ran great and I have taken care of it. 223,000 miles on the car. I just put in a new AC compressor and now I'm overheating. I know the AC draws alot of power but what can I change now to stop overheating? Thank you.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Probably not an answer but make sure the belt is at proper tension. Make sure the water pump pulley if fully engaged and turning. See if there is a difference when the ac is on, and when its not on.
Был ли этот ответ полезен?
Оценка 0
2 Комментариев:
The tension is good, the fans are ruining strong, I did a coolant flush a month ago. I looked about an hour ago and I was really low on coolant. I filled her up then drive her for an hour and she kept a good temp. I know I filled her full when I did the flush. It was over 100 degrees today. Maybe just to hot for an old car but I changed the compressor to have ac on days like today. Thank you for the reply.
из
No problem. I just assumed your coolant level was correct. Good to see you keeping and older car going.
из
Добавьте свой ответ
BRANDON S RHEA будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 3
За всё время: 208
