How do I fix it so it will take a charge again
I have 3 makita 18 volt batteries that will not accept a charge anymore, they are "bricked" as I've been told.
Is there a way of fixing this so I can still use them short of rebuilding them with aftermarket parts?
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
Наиболее полезный ответ
There is no easy way to fix them so the charger will accept them again, there is a PCB inside with a control chip that tells the charger if the battery is somehow under-volted and it stays that way even after a manual recharge of the individual cells.
One way is to use an RC-charger with low current directly on the battery poles.
Another way is to change the PCB, like this: http://www.instructables.com/id/Makita-1..., there is a number to an ebay item in comments.
I have even seen a guy who soldered all the components off the PCB and hooked the cells to the yellow connector, and them modified a charger so he could do balancing with an RC-charger.
Был ли этот ответ полезен?
Оценка 2
Добавьте свой ответ
ralphacrawford будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 387
