Дата выхода 19 сентября 2014 года. Это маленькая версия iPhone 6 Plus с 4.7-дюймовым экраном.
4994вопросов Показать все
iPhone 6 - Wifi 2.4Ghz Very Weak, 5Ghz Works Good BT too
  1. 5 Ghz works perfect
  2. Bluetooth works perfect
  3. GPS works perfect
  4. 'WiFi signal 2.4 Ghz is very weak'
I read quite all questions posted here, the more I could not solve my problem.
I'm sure it is a hardware failure that has already performed all software testing
I tried a few things I've seen posted here ...
Images are illustrative and not real ...
I tried to clear the Wi-Fi contacts that are located in the upper left corner of the board logic. Unsuccessfully.
I removed all the logic board and tried to clean the contacts again, this time cleared the front and back ... also without success.
Multiple users suggest scratch the Wi-Fi contacts for better conduct of the board, also performed unsuccessfully.
And finally I checked if the plugs from the back of the logic board are four slots if they were correct, without success ....
Already exhausted attempts, does anyone have any idea?
Sorry my bad English ...
Это хороший вопрос?
Оценка 4
Добавить комментарий
3 Ответов
look for c5213_rf / r5214_rf / c5211_rf
Был ли этот ответ полезен?
Оценка 0
I have the same problem
Оценка 0
Replace the antenna
found here:
iPhone 6 Logic Board Antenna Flex Cable
iPhone 6 Logic Board Antenna Flex Cable Изображение
Продукт
$9.99
Оценка 0
1 Комментарий:
Didn’t work.
из
Добавьте свой ответ
marcoaurelioborges будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 10
За последние 30 дней: 15
За всё время: 4,492
