Do you charge the phone for around an hour. If no, try it and see how.
If yes, try to press volume up, home button, power at the same time. This works for my s7 edge that have the same issue with you. If nothing comes on, try to press volume up and power at the same time.
Also try to replace your battery, a dead battery may cause phone not to boot.
Still no response? Maybe your logic board maybe dead. If yes, return your device ASAP before the warranty is void.
Warranty void already? You should run out of luck, you can't fix it anymore. Because normal users can't do it
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
5
11 Комментариев
j2 switch off on problem succesfully
из tarun
Hi I have the same problem with my Samsung Galaxy young 2 I tried to press volume, home and power button but it's still not working is just turning off and turning on
Please help
из de lo
My phone is samsung j2 pro now my phone battery is full just i switch off the phone than see battery is low plz give me a help
из Shubham Kumar
G318H is not turn on or turn off.
Please please help
из Sylvi Iyaloo
my j2, I actually had reset my phone and then rebooted it since it is the only way that I saw that can power in my phone because there are these like choices saying if I want to reboot it or have reset or have it updated and chose reboot. now it's like 30 minutes and my phone keeps only on vibrating and displaying the Samsung word on it
из Athera Avery
Показать 6 больше комментариев
