Xbox One — третья по счёту игровая приставка от компании Microsoft, являющаяся преемником Xbox 360.
Вопросов 20 Показать все
Fan turns on and off three times, then unresponsive. Advice?
Hello,
I've been refurbishing an Xbox One that was original smashed when I got it. After I got all the parts to repair it, I partially reassembled it to test it. I would go to plug it in, and a few seconds after plug in power, the fan would spin for a few seconds, than turn off. It repeats the process three times, at the same time the power supply goes from orange to white, in the same sequence. The Power button does not light up during this, although you can hear the "start up" sound effect when you press it while the power supply is white.
Here is what was replaced:
- Heatsink and Fan (thermal paste replaced with Arctic Alumina, Fan is a third party replacement.)
- The Full interior and exterior casing for the Xbox.
- Wifi Board
- RF Module Board
- Speaker for button feedback sound
- (The Wifi Antenna will also be replaced when I receive it. There is currently none attached.)
Here is what I've tried so far:
- Different Power Supply (Same result as before)
- Checked Hard Drive for Failures (I was able to navigate the hard drive on my Macbook Pro, so I don't think thats the issue.)
- Attempted hard reset by power button, but it doesn't seem to work.
- Startup from Controller plugged in. (no result)
Any other ideas I can try? This is a 500GB Original Xbox One Model - if I recall correctly, the 1540. (One of the earlier ones) Any advice would be appreciated. I've been testing this with everything installed in the metal casing, with and without the wifi board, with the bottom portion of the outer casing attached.
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (1)
Выбранное решение
This is often times caused by a faulty Southbridge but there are a lot of other things it could be. Usually replacing that chip will fix it but no guarantees.
Sorry I don't have better news for you.
Был ли этот ответ полезен?
Оценка 2
4 Комментариев:
Thanks for the info! Is there anything else I should look at before going after the Southbridge?
из
Any burned components or anything that looks like it might be bad or broken on the motherboard.
из
Or try to reflow it using the Xbox 360 RROD heat gun fix.
из
Turns out the motherboard was more damaged than I original thought - it got cracked from the original damage to it, making it unusable.
из
Добавьте свой ответ
Ben Eccles будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 4
За последние 30 дней: 5
За всё время: 778
