Пятое поколение iPhone. Ремонт данного устройства простой и требует только отвёрток, лопатки для открытия и терпения. GSM/CDMA / 16, 32 или 64 Гб / Черный или Белый.
2201вопросов Показать все
Battery replacement caused a boot loop?
Just replaced iphone4s battery but all it's doing is turning in I get the apple symbol but then it shuts off an just keeps doing this????
Это хороший вопрос?
Оценка 1
Добавить комментарий
2 Ответов
Try the easy stuff first:
Hold down home and power at the same time and let the phone reboot. If that fixes it, great. If not...
Connect the phone to your computer. Hold down power for 5 seconds, then press and hold the home button, while still holding the power button, for 15 seconds until the apple logo appears, release the power button and continue to hold the home button until "connect to itunes" shows up. At that time go to your computer, restore the phone.
Should get you back up and running. If it doesn't please report back.
Good luck.
Был ли этот ответ полезен?
Оценка 0
Hello, i have the same problem, i changed battery to fresh new one on my iphone 4s and iphone is boot looping, Apple logo shows for few second and then is dissapiers idk what to do, do you have some more solutions? I tried what you posted and nothing worked 😕, please whrite back ASAP
Оценка 0
Добавьте свой ответ
Sandra Jobson будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 6
За всё время: 517
