Дата выхода 19 сентября 2014 года. Это маленькая версия iPhone 6 Plus с 4.7-дюймовым экраном.
4994вопросов Показать все
iPhone 6 charging from 2 oem cables out of 6 of them
Hello ifixit family! so many apple devices in the house and all of them works with all oem cables except one of the iphone. Iphone 6 works only with 2 of them but im sure all of them oem and im not using after market cables. After plugged in saying that this cable is not certified and i know it it is oem apple cable. What could be wrong with it? Very strange thing and this is first time i see this issue. Thank you
Это хороший вопрос?
Оценка 0
2 Комментариев:
Try cleaning the charger port on the phone with the issue. Use a toothpick or something equivalent to clean it. Otherwise it may need the charger port replaced or at worst the charging ic chip is faulty in a way (need someone here to verify if this is a possibility judging from the symptoms or not)
из
Did all that, after that i did replaced the chargind port and still the same.
из
Добавить комментарий
1 ответ
They are not all the same - though looks like pretty similar. You are after Apple MFI Certified Lightning to USB Cable.
Был ли этот ответ полезен?
Оценка 0
2 Комментариев:
all of them authentic for sure. Even says on them design by apple in california
из
You are not the first one to have this issue.
Been having it on a client's iPhone 6 and iPad Mini.
I don't think much can be done about it other than finding a charging cable that works with the phone.
из
Добавьте свой ответ
Harley Davidson будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 96
