Sony Xperia Z3 Compact выпущен в сентябре 2014.
82вопросов Показать все
Water damage - No Display - Components missing
Hi Guys,
I've been tasked with repairing this Water Damaged Xperia Z3 Compact which has lost its display. There is visible Damage/Corrosion to the LCD connector which I've cleaned of, but on closer inspection there are a couple components missing just beside the connector. I was hoping that one of you tech geniuses would be able to identify the missing components and give me a fighting chance of resurrecting this phone..
Zoomed In..
Many Thanks In advance
Paul
Это хороший вопрос?
Оценка 0
2 Комментариев:
Great pics, I unfortunately can't help on this once, but google up schematics and you may be able to figure it out from there.
из
@ifixphonesuk Sony only offer board swap for phones in warranty, They do not repair boards therefore schematics are no longer produced. You 'll need a working board to determine what component this is.
из
Добавить комментарий
1 ответ
very low % repair, good luck if it's a hobby however commercially it might not be viable.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Paul Tulip будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 3
За всё время: 883
