Samsung Galaxy S7 (SM-G930, SM-G935) — смартфон седьмого поколения линейки Galaxy S, анонсированный компанией Samsung Electronics 21 февраля 2016 года на MWC в Барселоне[
369вопросов Показать все
Line in middle of screen after drop
My grandson cracked the side of my Galaxy S7 Edge. Now there is a line in the middle of the screen. Can anyone tell me what part to replace?
Это хороший вопрос?
Оценка 0
Добавить комментарий
4 Ответов
I would check the connectors in case they maybe were jarred out of place, but if not then the LCD will need to be replaced. This is not likely going to be a cheap affair given how new the phone is.
Был ли этот ответ полезен?
Оценка 0
Reconnect the screen flex cable or replace a new screen. The cable may loose or the screen is broken.
Оценка 0
The same thing happened to me, although all apps are working, my s7 edge ...is flickering all the time... Would that be a sign of a lose flex cable? I tap the back side of my phone, where the flex cable is connected...then the image in my phone's screen changes.
Оценка 0
I picked up a MacBook Air on Craigslist for $100 with a dead, swollen battery & horizontal + vertical lines on the screen. Replacing the battery somehow triggered slow, fluttery, goofy booting & a left shift key which doesn't work or uses ALL CAPS which can only be reset with a restart :-/ Upgrading the OS to macOS High Sierra did not help. After a few months, Apple updated macOS High Sierra, which fixed everything except the lines on the screen. I'm happy with this $100 MacBook Air now, lines on the screen included. I wish I only had 1 line on the screen :-)
Оценка 0
Добавьте свой ответ
Laura Freebury будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 3
За всё время: 1,279
