Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
745вопросов Показать все
Compatibility for case pieces between A1278 models?
I bought a 13" unibody MBP not too long ago, and it runs well, but the casing is in rough shape. There are scratches all over the lid and the bottom, the keyboard is dirty, and the bottom cover is held on by just one screw. I'm trying to find a for parts MBP that I can salvage the casing from, but I'm not having any luck finding the same model as mine. What I need to know is, are A1278 parts compatible across the board? Could I buy an aluminum 2008 MacBook and use the casing from that? Or am I restricted to the same exact model as mine?
Thanks.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
I have a ton of bodies for those. The 2009 and 2010 has the same body and display. The keyboard is different on late 2011.
No, you cannot replace with 2008 because there is none.
It is not expensive but you need to be careful with the tiny connectors.
Был ли этот ответ полезен?
Оценка 2
1 Комментарий:
If you buy on eBay the top case with KB will cost about $45 and LCD back panel is a little more. I would suggest not to waste money for the old machine as it is worth less than $250.
из
Добавьте свой ответ
[deleted] будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 251
