Repair guides and support for Android tablets made by Dopo, also known as Double Power.
34вопросов Показать все
How do I change the language from Chinese to English
I need to reset my dopo M975 tablet because it is in chinese. I have had it for awhile and have never been able to change the language back. Is there a tutorial online or is it best to reset the tablet? I'm fine either way I just want to use it.
Это хороший вопрос?
Оценка 2
Добавить комментарий
1 ответ
If you want to do a factory reset of the Dopo M975, ifixit has instructions. View the question, Why does my tablet keep freezing?
This will erase any data on your tablet.
I also found a tutorial on youtube that shows how to change the language to English, that may help you. You could view other videos with similar titles that might be closer to what you're looking for as well.
Lastly, page 19 of the manual has a screenshot of the English menus that you could use the respective icons to Navigate to the language menu that can help complement the video I referenced.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Tricia будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 5
За последние 30 дней: 8
За всё время: 1,052
